Free Guide Rail Adapter with any 18" TSO Triangle Purchase - Through 7/30
TSO_Products
Retailer
[size=18pt]Transform any 18" TSO Triangle into an XL guide rail square with our Triangle to Guide Rail Adapter—free with any 18" triangle purchase! This offer is good through July 20. No coupon needed; the adapter is automatically added to your cart at checkout.
Much more than just woodworking triangles, the TSO Products PTR-18 and MTR-18 are first-of-their-kind tools combining CNC machined accuracy with a wide array of useful accessories to enable countless measurement, marking, clamping, angle measurement and jig scenarios. TSO layout triangles are designed to complement today's modern 20mm MFT-style worktops by offering a variety of different attachment methods, and they can even be connected directly to track saw guide rails for fast and accurate angle cuts. Made in the USA from thick precision aluminum tooling plate guaranteed to be square to within .001" over their entire length and anodized for a protective and non-marring finish.
Shop TSO Triangles
What else is new at TSO?
JUST RELEASED! GRS-16 PE v2 Guide Rail Square for Festool, Milwaukee & Makita Track Saws
"Version 2" of our popular guide rail square now includes a fast attachment feature: simply insert the square at any point along the guide rail and clamp it in place—no need to slide it into the guide rail from one of the ends or remove hose deflectors, clamps, or other accessories occupying the guide rail T-slot.
JUST RELEASED! GRS-16 PE D Guide Rail Square for DeWalt Track Saws
The proven design of the GRS-16 guide rail square has now been adapted to fit the DeWalt track saw system! Like the original GRS-16 and GRS-16 PE squares, the GRS-16 PE D makes it lightning fast to achieve dead square cuts with your DeWalt plunge saw.
MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares for Festool, Milwaukee, Makita & Triton Track Saws
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
Padded Storage Bags for Precision Tools
Whether in the shop or on the job site, a little insurance for your fine tools is always a good move. Check out our new padded storage bags for guide rails up to 55" in length, parallel guides, and precision triangles.
