I recently bought a Festool OF-1400 router that had some accessories that I have no use for. I will ship for actual costs to your zip code.
You can email me @ jkc -at- thececils -dot- net
Festool Angle Arm part # 486052
For use with OF 1010 router in conjunction with copier scanning set to copy workpieces. Also for use with OF 1010 and OF 1400 routers in conjunction with edging plate for flush trimming operations. $25
Diamond Glazed 1-3/8"x3-1/2" Drum Router Bit
The guy I bought the set from said he paid $250 for this bit and he used it on one sink job. This bit is commonly used for following a template to cut out sink holes. It also works as a flush cut router tip for counter lips and edging. You use this bit wet. Never cut with it dry. It has a line around the circumference showing it was used once, but shows absolutely no signs of wear (see photo). I have included good close up images so you can see exactly the condition of the bit. Don't confuse this bit with a diamond vacuum glazed drum. They have little holes drilled in the sides of the bit itself and they're just cheap and wear quickly. This is not a vacuum glazed bit. $100
1/4" Diamond Glazed Roundover Bit
Does not look like it has ever been used. I have included a good close up image so you can see exactly the condition of the bit. $50
