I am using it on a quarter sawn beech top that measures about 8 by 3 feet. I stuck the boards together using just a ts75, no joiner, and domino. After sanding to up to 220 from 80 I hit it with a coat or two of Danish oil and let that cure for about three days. I sanded with 320 between coats of the oil. I was trying to pop a bit more of the grain with the oil but, to be honest, I don't know if it helped. Certainly didn't hurt but three days is three days. I'm on my fifth coat of arm r seal in a gloss and I sanded the first two coats with 320 brilliant. The next coats with 400 brilliant. Got a hair in the fourth so that's why I'm on five. Looks like a mirror if that's what you're going for. Going to hit it with 1, 2, and 3000 platin and then polish it up with 5000 and 8000 compound. Kind of a pain but go light, go often and don't pick at it when you're applying it. Let it level out. Room temp and humidity helps a bunch. Best.
