Hello! I just bought a TSC 55 REB, and 55” and 75” guide rails. I followed the instructions and videos to make the initial cut on the 75” rail after adjusting the knobs to remove play - no problems. When I switched to the 55”, however, the saw was loose and needed to be tightened. Problem that I’m running into is that at the 55” setup, the saw is way too tight for the 75” rail (it effectively won’t move). My plan is to join the rails so that I can cut full sheets of plywood, but I’m not sure how this could work given the different tolerances needed for each rail.
Has anyone run into this issue before? If so, have any suggestions? Apologies in advance if this has already been addressed - this is my first post and I’m tapping this out on my phone in a freezing garage.
