The strips hold quite satisfactorily to prevent the guide from sliding. however, if you are used to holding a non Festool type circular saw against a guide board, or a speed square, you are probably used to putting lateral pressure against whatever guides you are accustomed to using. In that case, old habits are sometimes difficult to avoid. For your first operations using the Festool plunge saw and guide bar, it might be wise to use clamps until you become accustomed to the idea of merely letting the combination of saw & guide follow the line by themselves.
It is probably easier for a newby to woodworking to operate with the theory than it is for somebody who has used (what i am beginning to think of as obsolete) older methods for many years.
Once you have become accustomed to the saw and guidebar, be very careful, you have then stepped upon the slippery slope. ;D
Tinker
