Tayler_mann said:
I have a 60 watt co2 laser that is CNC of sorts. It is a Henry rifle as well. I just designed and engraved the image onto the stock.
Have you ever tried using the laser on aluminum or some other metal? Probably needs more power for aluminum?
I don't know jack about small lasers, but you've piqued my curiosity about using one.
You say CNC of sorts, do you have a picture of your set-up to share?
My experience is with industrial lasers and designing a method to laser mark polypro and teflon carriers just below the surface with batch numbers that are used in the semiconductor business. Those lasers were in the $500,000-$600,000 range, so I never thought about a laser for a home shop. Then again that was 20 years ago.
