Lengthy, but hopefully succinct…
My sanding capabilities are 'under-resourced' and inadequate in terms of dust collection.
A couple of projects are looming with finishing of sheet goods required (to be clear-coated or waxed, in a few cases painted) - mostly birch ply, some Valchromat, probably some ordinary mdf too. Panel sizes range from 1' 6" x 1" to up 8' x 1', but mostly middle of that range (say about 2 to 3 square feet).
Had been looking at a large-pad sander such as RS2 or RS200 type (would that be appropriate?).
However... because:
a) I have other pressing purchases to make (for eg, a better vac - thinking 'Midi');
b) number of panels for immediate project is modest by pro standards - maybe 20 or so;
c) I have fairly generous (and maybe flexible) deadlines...
I was wondering about the vacuum hand-sanding pad (HSK-A??) using the same large-size abrasives (115 x 225).
So, the questions:
1) Anyone used that hand-sanding device? How did it go?
2) Presumably, unlike with the RS sanders, I wouldn't be able to use the FS hole punch to be able to work through an existing stock of ordinary plain-backed abrasives - because there'd be no way of fixing it to the pad; is that correct?
3) Any other experiences or advice on hand-sanding with DC?
4) Am I crazy to contemplate that much hand sanding and expect decent results?
5) Could I expect good results for finishing sheet goods from a more versatile sander, which might be a better value purchase for the longer term?
I know that the first thing you will ask is 'how much similar work do I expect to continue doing'; the answer is probably 'some' (my life is in a state of flux just now!) but given other potential expenses, I'd like to get these projects underway - and I'm thinking that hand-sander could be useful later regardless of whether I go on to get a large finish-specific sander.
Any thoughts appreciated; thank you.
However... because:
So, the questions:
