Hardwood floor refinish
batmanrobin
Looking for comments, ideas and info to finish oak hardwood floors. I"m gonna be sanding down floors with light stain and maybe whats left of varnish.  Floor is in good shape except for some roughness in spots. Will be staining a dark finish. Looking for any suggestions on grit, stain brand and clear coat for finish.  thanks guys
Assuming your using a floor edger and 220 belt sander, you would
Depending on how old the finish is, we use 40 grit next we use 80 grit on both edger and belt machines. End with 100 or 120 on the big machine(belt). You can climb the grit ladder more closely if you want to ensure a perfect job. EX.-40,50,80,100
We then scrape the corners and finish them off with the RO90 delta.
Then we RO150 all the spots that we used the edger on.
Lastly we buff the floor with 120.
The biggest tip I can give you is, with dark stain, you should waterpop the floor prior to staining. This will re-open the pores and allow the floor to accept more stain. But more importantly it will remove any buffer swirls and give the stain an even look. It will blend all the edges and hide many errors that might not have been seen during buffing. After sanding use a mop or wet rags and wipe water all over the floor. Dont soak it but def. get the wood wet. Let it dry before applying the stain. Just trust me on this.
Dont use minwax slow drying stains. Instead use the new stuff that dries quicker. Lowes and HD both carry fast drying stains now. They will look the same and will dry overnight.
As usual samples are your best bet.
We buff the stain on with a carpet pad cut to the buffer size. We remove with terry cloths placed under the buffer. This will speed things up and save your back.
If you've never done this before I would HIGHLY recommend getting someone who has to help. Or go Natural. A dark stain is the hardest floor to do IMO.
Feel free to IM me any questions you might have.
Here is some examples of our traditional stain jobs
http://www.flickr.com/photos/ecooptions/sets/72157627719885035/
Ask Eco about his Rubio work, he is the specialist in that area for sure. His work is some of the nicest I've seen, I agree with everything he said, dark stained floors are the toughest to do, your sanding MUST be perfect, or your gonna see every edger swirl mark, or even linear marks from whatever drum or belt machine you use.  If you plan on doing the floors yourself with rental equipment, it will be some long and aggravating days for you. There are a lot of tips and tricks involved in making an old floor look like a piano finish. Do a lot of you tube searches for techniques. If you have never run a belt machine, make sure you practice first, on say plywood.  You can destroy your floors in seconds.  Good luck..  Sam
