idratherplaytennis
- Jul 6, 2015
As per the title- I've got need to rip some laminate flooring out of my kitchen (floating floor) to install some new cabinets, as well as to cut out a damaged piece in the middle of the floor and I was curious who had done something similar before with a tracksaw.
Normally.. I'd buy some cheap blades and use my skilsaw and freehand, especially considering how tough this laminate is- I remember going through 4 laminate blades (at least) installing a small 500 square ft or so in my place. But the thing is I now have the new ts60 as a result of a double birthday gift- and I just wondered if anyone had used their track saws for tougher- more water resistant (ie denser, more plastic less organic) laminates around 12mm thick I believe.
My alternatives- stick with the cheap diablo blade and skilsaw or use my now backup Makita blade and track(s) with questionable blade life left. I can't easily get the Makita tracksaw blades, but I can get the skilsaw blades and the Festool blades locally. Or I try the ts60 with I'd assume the laminate blade and risk damaging the sacrificial cut strip on 1-2 tracks.
Just wanted to check if anyone had gone with any method over the other and had any experience and if the festool blades are all currently pretty good at keeping the cut strip the same or not. I'd read mixed reviews as to swapping blades, even if they have the same diameter kerfs and blade thicknesses, but those posts also went back years and years and unfortunately my local festool dealer lost their most knowledgeable guy to retirement so I've got to check where I can for info.
The safe money I think is risking the older Makita blade or skilsaw.. but the itch to use the ts60 is strong if the laminate blade is good for more than just melamine/formica type of stuff and not risking messing up my sacrificial cut strip(s).
