S smorgasbord Member Joined Jan 7, 2022 Messages 1,644 Location NorCal Apr 20, 2025 #21 <Deleted> Last edited: Apr 20, 2025
S smorgasbord Member Joined Jan 7, 2022 Messages 1,644 Location NorCal Apr 20, 2025 #22 Michael Kellough said: This 4-1/2” diameter blade has a 20mm arbor, 36 teeth, and the smallest kerf I’ve found. Don’t remember the exact width but it is barely wider than the fine tooth jig blade you’ll need to finish cutting inside corners. Click to expand... Got a reply from an Amazon seller of that blade: 0.039" blade thickness 0.049" kerf which is about 1.25mm That's pretty thin, but I did fine this 5.5" diameter (140mm) blade that is equally thin: https://www.amazon.com/dp/B07V5QL63S I ordered it to try out for dovetailing.
