yetihunter
- Apr 21, 2013
Michael Kellough said:With this kit you don’t “suck dust through the router”.
But it’s probably not handy if you take the router out of the table often.
YMMV, but I went through two of those types of kits and remember having issues. They both got traded out for a box. I ended up with an incra box at some point too, it worked.
My frankenstein woodpecker/incra/general/jessem/routerraizer/elu router tables worked just fine, but I’m going to always recommend at least an all-in one table instead of cobbling it together like I had done in the past. I did save a lot of money (never spent more than $400 a table...with router table parts, nothing milled or sized by muah). They have them set up now where you can get everything included that had to be bought separately mere years ago.
Stan Tillinghast said:OK, now you guys have me wondering again.
I always liked the sliding table on the FT router table; and I already have an OF 1400.
The full kit price of the Festool rig is not much different from the Jessem or Woodpeckers setups with a nice micro-adjust fence; and I have an old Bosch 1617 (I think) I would use for a motor.
I for one would appreciate more details on your experience with a Jessem or Woodpeckers router table, particularly in comparison with the Festool. Mobility is not an issue with me, but shop space is of course.
The Festool takes up more space than the Jessem/Woodpeckers/Jet/Sawstop/Kreg/etc tables when fitted with all of the extra tables. But you don’t need to have those tables up all of the time. I haven’t touched anyone’s CMS in a while, so hopefully someone can chime in with how stable it is. That’s the only concern I have with my recommendation. You can build or buy a coping sled or sliding miter attachment if you go the non-festool route. I’d rather have the aluminum table over phenolic/melamine. Likewise, I’m sure others will say they'd rather have cast iron over the aluminum. An easy way to help your decision is to decide what router you will be using and what dust extractor. CMS means you’ll be using a Festool router and a european portable dust extractor (Festool, Fein, Starmix, Nilfisk). Unless any new developments have come about since I put woodworking on hiatus a couple of years ago, you will need the larger stationary machine dust extraction fittings the other router tables and you won’t be using a festool unless you drill out your own plate (it will be aluminum or phenolic, so not a big deal),
