PA floor guy
- Nov 25, 2012
146 dollars. What!!!! I could not believe it. Where do you guys send your blades for sharpen.
Peter Halle said:When choosing a sharpening service make sure that they can sharpen the Festool blades - particularly those of the Kapex. Some can't due to the variable tooth spacing.
RKA said:[member=63238]Tracky[/member]
What grit do you use/suggest for a final pass on carbide bits and blades? I'm finding some say 600 but others suggest 1200.
I just mangled a dovetail bit (clamp slipped - bit meet washer). DMT makes a diamond flat file (V shaped) but the finest grit is only 600. Their rectangular flat files go up to 1200, maybe higher, but the form factor isn't ideal for some router bits.
Peter Halle said:Festool blades are manufactured by Leitz. When choosing a sharpening service make sure that they can sharpen the Festool blades - particularly those of the Kapex. Some can't due to the variable tooth spacing.
Peter Halle said:By the way item 203150 is still a available here in NA. 1 60 tooth and 1 80 tooth. Current price is $210 USD.
fshanno said:Peter Halle said:By the way item 203150 is still a available here in NA. 1 60 tooth and 1 80 tooth. Current price is $210 USD.
For both?
fshanno said:I'm running the original 5 year old blade in my Kapex. Never been sharpened. Time for something new. The set looks like a good deal.
But I'm curious about the Oshlun blade I see on Amazon for $55. At that price it's worth experimentation. If it proves to be inadequate it can always serve as a backup blade for cutting questionable stuff.
I bought the $25 Oshlun 48 for my 55 back in May and it's never been off the saw. New out of the box rips were just as good as the Festool 48 tooth. Crosscuts were very close, not quite as good as a new Festool but acceptable. I figured I'd get one kitchen out of it. I did get that one large kitchen but it's still going strong. Very nice rips and respectable crosscuts.
