Christian O. said:
There should never be the need to calibrate a tool you are buying from Festool. If it doesn't work out of the box,
return it. In no case there should be a need to enlarge screw holes or do similar alterations.
Each tool is calibrated in the
factory and is quality checked several times. In case of the Domino, they are doing test cuts with every
machine in a piece of wood and measure
the mortise. They keep that piece of wood and mark it with the serial no. of the Domino, so they can go back and
check the mortise in case of a complaint. They also have several other calibration stations for the Domino. Everything is done to make sure
you are getting a Domino that works out of the box.
We are getting reports from Dominoes that need calibration after they have been bought. In order to find out what
the problem is, we need a Domino back before somebody tried to calibrate it himself. We have yet to get one of those Dominoes
back. We are only getting Dominoes back that are completely out of whack because of calibration attempts. We can calibrate
those Dominoes for you, but we cannot find out anymore what the initial problem was.
Please help us finding out what the problem is, by calling our service no. before (!)
you try to calibrate it. Both repair shops have measuring devices, specifically developed for the Domino, to check the Domino. We can measure the Domino and then compare our measurements with those of the Festool factory to
find out what the issue is.
Last but not least: When you are getting a new Domino, please keep in mind that it takes a little practice to get perfect mortises. Don't
judge the accuracy of the tool after the first couple of mortises. Cut 20 mortises until you feel comfortable using the tool, then do
a test mortise and check the accuracy.
Thank you
Christian
