I am in the middle of making a bookcase ( three separate modules ) to sit on a desk I have previously made . On the first module I attached the carcase sides to the face frame with pocket screws. I want to know if I can use the domino to attach the sides on the other two modules to their face frames. If so, please explain the procedure. The face frames are 3/4 " cherry and the sides are 3/4 " cherry ply. In the middle module the sides will be flush with the edge of the face frame and in the outside module the outside will be offset 7/8" to allow for a raised panel end cap . How deep should the mortise in the face frame be ? What size domino would you recommend ? How do I register the domino for the cuts in the ply and face frame and allow for the 7/8 " offset on the outside ? Sorry for all the questions.
Thank you sooo much in advance for your assistance.
Jim
Jim
