Bob Gerritsen
- Feb 10, 2012
Hi all,
So I've installed this wooden floor, smoked brushed and oiled oak, laminated boards but the top 5 mm is solid oak. Then afterwards the electricians came in to drill quite a few holes in the plaster ceiling, without covering the floor or even using a vacuum. To really top it of they've used a WET broom to sweep the floor afterwards...
Now my client has already spent a whole morning on hands and knees and cleaned a lot of the mess up but it is quite obvious there is plenty damage done. The plaster dust in combination with the water from the broom has really penetrated the floor and there are whitish dull areas all over. Plus the broom, that was wet from being used outside and also had sand and what not in it, has left subtle but quite visible brush marks across the grain of the wood on the worst areas.
Regardless of who's fault this is and who get's to pay for it, it is clear I will be tha one fixing this. As for the options to restore this floor to it's initial mint condition, a couple thing have crossed my mind:
- As the floor is brushed, I don't see how sanding it would do any good unless I'm going to take of at least 1,5 mm or something like that. Than however it would not be brushed anymore but polished flat so that's really not ideal. Any partial or light sanding would (I think) only create weird looking areas. In general sanding is a no go as the brushed surface now, with peaks and valleys of different height/depths, simply doesn't allow that. Right?
- I think the plaster, as it has been in contact with water and being sort of brushed in has both penetrated the wood further and then dried making it fit perfectly into the cracks and veins. I can't think of a way to get that stuff out of there.
- It also looks as though the plaster dust has partially sucked the oil out of the wood.
- The only thing I can think of to repair this floor is to oil it again, hoping the oil will cover up or maybe color the plaster in the wood and the same with the marks across the grain. I expect though this can only ever be a partial success simply because it will make the damage less obvious but it doesn't really deal with the problems. Right?
Any thought or experience out there??
Cheers, Bob.
Cheers, Bob.
