NewWoodWorkerVA
- Jul 30, 2023
Moving my 1 car garage workshop into the "basement" which is currently a theater room. Going to get rid of the beautiful high-pile, thick-pad carpet since that room got little use. The back wall is basement with probably 8 feet of earth; the side walls slope and the front wall is ground level with the garage (house is built on a slope).
I've done a lot of research here and on YouTube on flooring options. I'm looking for something that will be 1/ easy to walk/stand on for hours and 2/ easy to keep clean. House was built in 2022 in Virginia and I assume has whatever barrier before the concrete to stop seepage. Current carpet is installed on a moisture barrier but the HVAC room is raw concert and I've never noticed condensation.
I was looking at the DriCore R+ tiles; they look nice (After polyurethane and sanding) and easy to install. But not sure I need their moisture barrier given my basement. Also looking at tractor supply 1/2 inch 4'x6' horse stall mats. Would be about the same price per sq ft (a bit cheaper for mats since I'd cover fewer sq ft).
I've considered epoxy (easier to clean up but would not be soft at all).
I saw a post saying to put down Advantach subfloor; that could be even easier to install than the DriCore. Would it be as comfortable? I'm ok with a "shop looking" floor i.e. I don't need pretty LVP; not opposed to it, but I think it would be hard to protect it from moving equipment around (though I wouldn't be moving it much since I'll have a lot of space with this new room).
Any thing else I should consider? For those with DriCore, are you happy with the "softness"? Any concerns with heavy equipment (Jointer with 3 points of contact, table saw, bandsaw) dimpling the wood?
