Hi Ive got a DF 700 I want to start making a cabinet. Ive cut my stock Im using 40mm dominos. 8mmm cutter
I Know you can use it on no less than 18mm. What Im struggling to work out is how you set up the boards for the cut when plunging into the face board. Because from the edge to the to top of the mortice the cut is 19mm when using the 500 technique of settinging the edgeboard back 18mm. I realise that now needs to be approx 6mm further back but is there an easy way of settting this up?
Does anyone no a good video or help for this type of cut?
Hope this makes sense.
