HELP PLEASE -How can I insulate a wooden lampshade top
Frank Pellow
A year or so ago I made a lampshade out of stained glass with a oak frame and top. But, the lightbulb was too close to the top  [embarassed] and resulted in this burning:
[attachimg=#1]
I am rebuilding the lampshade so that I can use a bigger harp which will place the bulb further from the shade. I am wondering if there is some insulating material that I can attach to the wood as well.
Possibly missing the point here, but use an LED bulb. Won't generate as much heat and save you a few quid.
I don't know much about led lights.  Can you get them with "standard" sockets and in tri-light?
I agree on the LED bulb! But watch out, there are usually a few color temperature choices. I tried some in a ceiling fan and it was like being in a hospital corridor, stark, annoying white light. The next step down was daylight I think, much better! Expensive up front but you will probably never have to change it again.
Yes people who buy "white" LEDs as a colour choice have generally never seen them. "Warm" white is closer to an actual bulb.
Not sure what you use where you live, but in the UK we have bayonet & screw fittings, all sizes are now available, most of them are around 3W and don't run hot enough to worry a hand let alone a lump of wood.
Hope that helps and saves time.
