This is the Mk. 1 system and I was having an issue with my drill chuck causing the top of the bit to tearout a bit and no longer fit through the parf boring guide hole.
In an effort to chuck it up a lot less, I just bought this Makita chuck adapter. It says it has a capacity of 1.5-10mm, so I chucked up the bit and cut my 1st hole. It wasn't deep enough, so I went to reposition the bit in the chuck and the d$mn thing is stuck in there!!! No idea how I could remove it without just cutting it off? Seems any force applied will screwup the whole guide. Is there a place to just order the Mk. 2 boring bit?
Any things I could try to extract this?
