Jeff Zanin
- Jan 2, 2009
I am making a 25.4 (yes, 1") groove, 280mm long, final depth 10mm, in a piece of plywood that is 153mm wide, using the OF-1400, the "parallel side fence" SA-OF 1400, and the rods supplied with the OF-1400.
This will be a series of passes to the final depth of 10mm, so it is important to avoid the bit wandering during the cut.
I have a second "parallel side fence", but the rods are not long enough to mount the second fence so as to capture the piece and prevent the bit from wandering.
A longer set of rods would be nice, and I may try to find something since I don't think these are available from Festool.
But for the two pieces I need right now, could I use a "guide rail adapter" FS-OF 1400 on the rods opposite the fence to capture the piece? These seem flimsy compared to the fence, but they fit on the length of rod available, and I will only apply side pressure on the fence side, so it is just to prevent twisting or movement of the fence away from the edge of the piece.
