AlexThePalex
- Nov 12, 2008
demographic said:Err, shall we just put that in a big box marked Not My Problem?
Maybe, but perhaps it might fit better in that big box marked Not My Solution.
xedos said:Do you use a particulate meter to measure air quality in your shop or jobsite .
Have you tested the difference the HEPA filter makes (if any) ?
I think what some of us are saying is that the HEPA filter doesn't make much of a real world difference in air quality five feet away from the extractor because it's only part of the overall system. We're also saying that a bigger factor in the overall air quality is the inability to capture all the dust at the source. And it's that dust which doesn't go through a filter at all; that contRibutes more to the air qualty than whether your secondary filter stops .3 or 1 micron particles.
I'm coming over next week, maybe I can bring you some HEPA filters if you can't find someone on Amazon or eBay to ship them to you direct.
Simon O said:I do see the point you raise about the inability to capture all dust at the source, although-
1.I'd be curious to know on what you base the assertion that this is the 'bigger factor'? By what margin? and
2. All I'm trying to do is optimise the effectiveness of the extractor, with the parts that are available to me, it's self evident that this is never going to be 100% capture.
The suggestion overall here is that installing a Hepa filter makes an insignificant difference to the dust in the air - again as far as I know there are no test results for this?
Thanks so much Alex I'll take your advice and go do some sanding and sawing on objects, then use my eyes to see the dust that the extractor does not capture - dust which ..... you know what, I give up - we're either talking at cross purposes, or you have not understood a word I've been saying. So let's just agree that we have different opinions and leave it at that.Alex said:Simon O said:I do see the point you raise about the inability to capture all dust at the source, although-
Just go do some sanding. Or sawing. On whatever object, you will find that even though you are using an extractor there is always residual dust at the place where you are working. Some of the dust you generate and is not captured by the vac falls directly down, and some of it is spewed into the air. Depending on what you're working on, the amount of residual dust can be very small, or very large.
But still, if there is dust you can see with your own eyes, it means it is a lot more than those particles that go through the filter, because those are so small you can't even see them.
Simon O said:you know what, I give up - we're either talking at cross purposes, or you have not understood a word I've been saying. So let's just agree that we have different opinions and leave it at that.
I haven't conducted any scientific, quantifiable measurements. I can see what is not captured by the system while sanding at my station and the dust in the secondary air cleaners nearby. Both are significant enough to see. Which means the little bit xtra the HEPA filter captures is really meaningless.1.I'd be curious to know on what you base the assertion that this is the 'bigger factor'? By what margin?
Then what would be the real point of the better filter except as a placebo ? In the OSHA rule , the government is mandating the performance measurement and levying fines for non compliance. This would be a tangible reason to have the better filter. Even with the HEPA filter I think PPE is still required , which should tell you something about the system right there.I'm not sure whether any tests I could conduct on a work site, would have any validity
Only in case the additional finer filtration reduces airflow, something that can be avoided by adding the fine filter behind the motor (instead of infront of it).Michael Kellough said:The irony of adding finer filtration to the vacuum is that less dust will be collected.
Gregor said:Only in case the additional finer filtration reduces airflow, something that can be avoided by adding the fine filter behind the motor (instead of infront of it).Michael Kellough said:The irony of adding finer filtration to the vacuum is that less dust will be collected.
Apart from that it's a general good idea to not inhale particles that can't be exhaled again (as you're unable to cough them out), hence to use HEPA. And to use a laser beam to check for presence of floating fine dust, check if the air cleaning setup might be in need of an upgrade...
A filter being between intake and motor can be exposed to a maximum of 1 atmosphere pressure differential (given the motor creating a perfect and instant vacuum and no other resistances except the filter exists). But a filter between the motor and the outlet can be exposed to a (way) higher pressure differential (if needed multiple atmospheres) without, given the motor being up to it, reducing the vacuum that is created at the inlet - and the higher the vacuum at the inlet (relative to the room) the better the extraction.Michael Kellough said:I’m not convinced the location of the flow inhibitor (fine filter) in a closed system makes a difference.
Yes.FestitaMakool said:Isn’t HEPA filters placed on exhaust side of the turbine/motor?
