this is a side question from my other thread but a different issue and thought the 2 would be better seperated
i have been asked to make a door for a kitchen press. they want a routed door with a 40mm stile width and a panel set in 1/4"back from the front. the first problem is them want mft vennered and painted for the grain, not sepeate stiles and rails one piece.
the second and more dificult is they want a herring bone pattern routered into the face of the panel. they want around a 2x 1 " rectangle at 45degree angle with the herringbone.
i will probable route the herring bone onto a 1/4"piece and rebate that into the back of the front piece with a square cutout in it.
how do you think i should make the herring bone pattern. the problem is that you need a groove for 2"then a gap for 1"and a 1"groove then a2"gap etc. a router on a rail will help keep them straight but setting stops every 2"or so would wreck you head.
i was thinking of using the lr 32 system and mounting the router to that. and change the 2"x 1" to 64mm x 32mm.
do you think this would work as it would give me a stop where i need it. the only trouble is keeping track of where i should start and stop
anyone have any ideas or jig ideas short of using a cnc
