ElectricFeet
- Feb 4, 2017
Many years ago, I bought a router -- a Black and decker BD780E, if you're interested; 600W, variable speed: that was impressive 20 years ago [unsure] -- with a few (poor quality) router bits. My career took over and I never really used it. I took it out of it's box some years ago and gave it a (freehand) spin, not knowing what I was doing really ... with predictable (that is, bad) results.
Now I'm retired and I've taken it out of it's box and I'm trying to bring it up to date / make it useable. And with the benefit of YouTube, I've learned how to use it properly. I've added a perspex base, as shown in the Samurai Carpenter's video ( ).
Now to buy some decent bits. Things have moved on since I first bought it, and I'm looking for upcut and downcut spiral bits and a few basic bits (45 degrees / rabbetting bits). (This video is fantastic on explaining all about spiral bits: )
BUT (and that's a big BUT)... the shank diameter is 6mm. Looking online, I seem to find very few 6mm router bits. They tend to be bigger 8mm or imperial shanks.
I found thesehttps://www.fine-tools.com/spiralnutfraeser.html and generally find that Dieter Schmid has good quality stuff. Strangely, they have spiral bits in 6mm, but they don't have the normal run-of-the-mill bits in 6mm -- they all seem to be 8mm.
Questions:
- Is it worth investing in the 6mm bits, or am I just throwing good money after bad? The router was pretty good (and pricey) when I bought it, but that was 20 years ago. Should I simply cut my losses and move on to another more standard (8mm?) router? Seems a shame to throw away a perfectly good router.
- Can I change the size of the "thing" in the photo to accept 1/4 inch? (I don't know what it's called, sorry). It's currently just shy of 10mm diameter on the outside (flaring out to 12mm) and 6mm on the inside. It's about 17mm high, with 12mm sitting inside the spindle screw before it starts to flare out. It will not take 1/4" (6.35mm) bits.
- Am I missing a major source of good quality 6mm router bits in Europe?
[Included 3 photos: (1) the "thing", (2) the thing inside it's spindle screw and (3) with the collet screw]
Questions:
