Hi everybody. I'm looking for some input on tool purchases for some upcoming projects. I'm trying to decide if I can get away with an HK55 for an upcoming project, or if I will need to buy a miter saw as well. And if I need the miter saw, I'm trying to decide whether the TS55 or HK55 is a better fit for me.
The first project is installing a deck over an existing concrete patio. The plan is to apply concrete patch/leveler to ensure positive drainage, then to install pressure treated sleepers, then finish with hardwood decking (ipe, cumaru, or garapa). The portability of the HK seems great for this. Take the saw to the material, cut to length, and go. Add a track, and I have the ability to trim all the installed desk boards in place. But there's a possibility we will install the decking in a "basket weave" pattern. In that case, I would need a bunch of cuts to the same length, so a miter saw seems like the better option. I also wonder if the HK will have enough power for the decking material we plan to use.
The second project is replacing all the interior doors. I plan to re-install new slabs in the existing frames, so there will be some trimming and or undercutting required. Either the TS or HK seem good for the job, with a track. Do I have to worry more about splintering with the HK?
And input would be appreciated!
