counterfix
- Jul 18, 2009
This hl 850 e has preformed great over the years but it has finally seized its armature bearing and rather then send it all the way to Indiana i will replace it in a few short steps.
first i want to remove the two screws on the brush plate then the two that's holding the bearing flange
know i can remove the plugin brackets by lifting them up with pliers and brushes have two screws
then lift the brushes up and out like this
now i can remove the cover for the tooth belt and take it off there are four screws holding the bearing flange to the planer housing
remove them and now separate the bearing flange from the housing like this
you can know unscrew the tooth disk from the armature clockwise then the armature is free like this
the tooth disk is the small gear on the armature. use a bearing puller to remove the bad bearing then press on the new one
now just reverse the steps to reassemble the nice thing about festool is the bearing ring is rubber when the bearing freezes it
won't destroy the housing ;D after your finished run the tool for a few minutes to seat the brushes know i can do another 100.000 LFT.
[eek] [eek] [eek]
[eek] [eek] [eek]
