So I got an old VS600 a while back as it was a good price and just taken it out to investigate!.. I Got the SZO 14 templates with it and note that I have a 17mm ring and dovetail cutter with it but am missing the other ring and bit.
The other ring I can see is meant to be an 8.5 and these are readily available, but the spiral bit code registers no where! I assume it is just a spiral upcut bit 6mm x 16mm?. Also, if so, will a regular 6mm fluted bit do?
I don't have the the entering mandrel either ( for the 1010) but I guess I could make something perhaps...
Please note I based in the UK
