Thank you all very much for the feedback.
wow I have so much to learn, the suggestions were very useful and thought provoking.
-16 sheets @18mm (casing and doors)
-2 sheets @ 12mm (drawers)
Lots of glue and domino's !
The setup was for the client and his three kids to use as an office, a guest bedroom, Kids homework area and band practice.
- All these affected the overall design and as the build progressed the layout was refined.
- I agree with having lots of draws which i built but was vetoed and were removed.
- The balance of doors and how they would open, was something that was an issue. In the end i gave them functionality in some areas and asthetics in others. Also at times i did what was better for the build in terms of time and ease of execution. The door on the wall unit in the corner is the way it is because its easier to hang on the left of the unit without building a small support section which would have restricted access to the very back.
- The end grain showing on the worktop was done as they liked it that way but again the option was given to them. They were really nice folk and so i gave them lots of options which i would normally decide myself.
- To the left of each seating position is a computer unit . The bottom shelf is on full extension runners so gaining access to the cables is easy. None of the bottom units touch the wall so the cables can run behind. The space is extra generous this time as the client ice climbs and has forearms like PopEye !
- The use of Oak was due to the cottage having an oak framed entrance and an oak theme overall.
- The doors were rollered with two coats of 'Dulux MDF primer', then 'Dulux trade Diamond Eggshell' with as many coats as needed.
- The MDf factory edges need to be managed, as painting them makes you go nuts as they feather and dimple endlessly. I try to keep them facing the back or just cut them off. Changing blades regularly keeps the feathering down. I learnt the hard way, going cheap on primer. Some primers are as viscous as milk, which is good for a tosh coat but to get a good opaque coat, i prefer thick high pigment count primers. Usual routine of sanding in between coats.
- At the moment I'm using a Matabo SXE450 which i am waiting to die to justify getting a rotex, [smile] same with my Fein vacume !
- The lighting track above is 9x 650mm T8 triphosphor lamps connected in series to the main room light. I used 9 to achieve an even light source. Under the counter are three individual lights for each station on a separate ring.
- The handles were the clients choice and at the end of the day as long as it does not compromise my reputation or work ethic i'll build what people pay me to. People pay good money for things i would refuse to have in my own house.
Once again thank you all for your comments and encouragement.
