Homemade mft done w/pics
rjwz28
I just finished my folding work table built similar to the Festool MFT. What I set out to do was to make a work table to hold my items while I work on them with bench dogs, clamps and a vise.  I'm going to use this when I use my Domino.  It had to be portable and folding and light enough for me to move around as I work in an open garage and I need to put things away when done so I can park the cars back inside.  It needed to be sturdy so I can sand and screw pieces together on it.  It isn't a heavy duty workbench where you pound things on it.  I have another one for that and also built a torsion box assembly table before.
I've tried making a table with folding legs out of wood but it wasn't sturdy when set up so I searched the internet for one where I could modify to suit my needs.  Just so happen that I got a Woodcraft flyer in the mail and there was this Vika Two-Fold folding table on the cover.  So I researched it on the net and saw it Had good reviews.  The dimensions aren't exactly what I wanted but it was the closest I could get.  The work surface is about 45” x 19”.  I wish it was shorter and wider but it'll do.
The first thing I did after setting it up was to take off any unnecessary things to reduce its weight.  This thing weighs 45 lbs.  There was a power strip, mdf top and a plastic crate bottom so you could turn it upside down and use as a scaffold.  I replaced the top with 3/4” plywood and drilled ¾” dia. holes around the whole table.  Next I took a vise I had and took it apart.  The vise was too heavy as it was so I made the main pieces with solid wood instead of the heavy cast iron.  I finished with poly.
I’m pretty happy how it came out.  It is sturdy and I can still move it around by myself.  If it was any heavier than this it would be too much for me.
Thanks for looking.
Rob
The two-fold can be had for < $150 if you shop around a bit, so I'd guess this was a fair savings over the cost of a genuine MFT.
Suggestion: mount T-Track around the table to allow clamping to the side, the way the MFT does.  I forget the exact size off hand, but there is a size of T-Track sold at Woodcraft that the Festool clamps fit into...
make it crosscut and you'll have a homemade mft, until then its just a m, f, or t table!
I have 2 of those Vika tables. Never thought to do something like that. They were really useful when rebuilding my fence as work and material stacking tables but found the hardboard side surface sure does not like to get wet!! Will take one apart and see about rebuilding it somewhat like yours for outdoor usage with a more weatherproof or resistant top. Thanks for posting this as gives me a few ideas. Yes I do have a MFT/3 and a MFT800 but some modifications to the Vikas would make them more useful to me for outdoor projects.
