I'm about to dive into putting up a horizontal wood fence in my front yard. I'm thinking of using Batu (Red Balau). There are a few issues I'm struggling with. 1) It's relatively expensive so keeping waste down is a priority. 2) you can specify that all the boards come in a certain length that you desire. 3) This isn't a problem but I think it's worth mentioning that I'm not completely opposed to using a B Grade Redwood product but am worried that if I'm to achieve a similar look to the hardwood that yearly staining might not look as good overtime as the annual oiling of the hardwood.
With that said I'm wanting some advice from others that might have done a similar project.
Here are a few pictures of what I'd like the fence to look like.
Im wondering if it's possible to joint the boards together end to end to cover the lengths I need and minimize waste. I have a domino jointer but have no idea how the stock dominos work in an outdoor setting. If it is possible to join them together with the Domino should I also cut some kind of joint to help it stay intact structurally? I plan to put posts up every 4-5 feet to allow adequate support for the horizontal boards.
Any help would be greatly appreciated. Thank you
