hose length
adrian130980
Hi
I have a festool ctl 26 and would like to know what is the maximum or recommended max length of 50mm hose?
Many Thanks
Adrian
adrian130980 said:
Hi
It would be to a kapex 120 or ts55
Adrian
You don't need the 50mm hose for either of those, the 36mm would be sufficient. The best solution for the Kapex is a 1.75m length of 36mm hose (buy a 3.5m & 2 extra fittings, make 2 hoses, sell the extra one), but that would be no good for the TS55!!! Works great as a dedicated hose for the Kapex though.
If you want to use the same hose for both, then go for the 3.5m 36mm (unless you have a specific reason to want to go longer?).
Hi
sorry i put 50mm by accident, i meant 36mm
i am attaching a kapex 120 and also separately a mix of ts55, domino xl & ts55
Thanks for all the advice
adrian
