There's been some posts here and elsewhere about static buildup frying the circuitry in Festool vacs. One owner said this happened with with an anti-static hose attached and no breaks between the vacuum and the tool. Others have said when they inserted a plastic cyclone in between the tool and the vac, they fried a board within the vacuum.
Is there any connection between static buildup and fried circuit boards? Will a complete static grounding path from tool to vacuum (plugged into a grounded outlet, of course) reduce or eliminate problems with static causing fried boards? If you do insert a cyclone, such as the Dust Deputy, in between the vacuum and the tool, should you also complete the static grounding path with a grounding conductor?
Or would none of this matter?
