Hot Tub enclosure, advice appreciated
SMJoinery
Hi All
Got a little project to form an enclosure for one of the round inflatable Lay Z Boy spa hot tubs.
I'm thinking hexagonal in lieu of round to simply frame as I want to make sure top collar round spa is well supported and makes it solid for getting in and out. However I might make the final cut on the inside of this collar round to follow the circumference of the tub.
Any ideas and tips on past projects would be appreciated.
The enclosure will "connect" to an existing deck by a little bridge path so nothing else around to interfere.
The tub will have to be removed in winter.
Thanks in advance.
Scott
What ever you build, make certain it's robust enough to withstand the stresses of time travel [wink]
Been out in the tub for inspiration tonight whilst it was chucking rain!
Water was 40oC..... [eek]
Last night it was set at 32oC.... [blink]
Tomorrow it's set for 36oC... [big grin]
Priorities first, Then I'll think about the enclosure!!
