Hi Festool family! This is my first summer with my newer model Rotex 150. That being said, I live in AZ where I'm currently at 114 degrees. During my build today, I started sanding my project and working through the grits as normal. Started with 80 granite and worked to 120. After only 6 boards of walnut that measure 8"x8"x6" and roughly 20-25 minutes of sanding, my rotex was HOT!!!
The best way to describe my experience:
On a hot summer day, lay your hand flat on concrete. You know that you can only keep it there maybe 5 seconds.
On winter, when you place your hand in front of the portable heater. That's how hot the air was coming out the vents.
I literally could not hold the sander from the handle. I had to hold it from the very top and the dust extractor hose.
I had to stop, check my paper, pad and even removed the (brand new) hard pad. Everything looked good. Tried to raise the ct26 power to maybe, maybe cool it down but nothing. Still hot. Very hot.
What the hell am I doing wrong? By the way, this was all on random orbital mode, new paper, and new pad.
