Michael Kellough said:Like CRG said, it’s up to you to dial them in but after that the results will be extremely repeatable as long as you take the basic precautions in setting them to the stock. Like make sure the stops are snug and that the stops aren’t sitting on splinters etc.
The sit on top versions are much more user friendly. I bought the TSO stuff and am very satisfied with it.
GregorHochschild said:For ripping a full sheet with two rails that are joined together, I was always struggling to get perfect results and constantly checking whether the rails are well aligned. Probably the precision was good enough over 2.4m but I wasn’t happy. I would want a single rail and I think that would have solved my issues with breaking down full sheets with tracksaw and parallel guides. Now I have access to a sawstop ICS and I am getting excellent results.
In short, your results with parallel guide will depend on the whole setup. A good and flat work surface is important as well.
Crazyraceguy said:Snip. Ripping full-length strips from a full sheet is just not in the cards for a lot of people's tablesaw either.
Snip.
ChuckS said:Crazyraceguy said:Snip. Ripping full-length strips from a full sheet is just not in the cards for a lot of people's tablesaw either.
Snip.
Norm Abram did it on his older and later newer tablesaws, using the workbench (built to the new table saw's height) as a support at the front.
Anyone who wants to rip sheets on their cabinet saw should consider mounting a JessEm stock guides to their fence. That guides not only prevents kickback but also holds the large sheet tight to the fence making feeding the 4x8 a lot easier. Still, it takes a mastery of the basic feeding skill to do the task with perfect results. Practice it on a 1/8" or 1/4" sheet if you want to develop the skill before attempting it on a 3/4" - 4x8 piece.
GregorHochschild said:Completely agree. Ripping a full sheet on a cabinet saw requires skill and setup. I ask the lumber yard to do one rip on full sheets whenever I can. That makes it so much easier to handle the pieces. Still a full length rip afterwards but lifting and controlling the pieces is much easier.
Overall, I still think it is easier and faster to get accurate results on a good table saw setup compared to parallel guides in most situations. Not saying it can't be done but it just requires more attention, careful alignment of the cursors on both guides etc.
Snip.
Spot-on. Rip cuts are not the problem.Alanbach said:Snip.The challenge came in with big cross-cuts in ply. Snip.
ChuckS said:Spot-on. Rip cuts are not the problem.
The track saw/ circular saw is the tool of choice for crosscutting. I sure wouldn't do it in the way these folks suggested in their video, given the risk of kickback (depending on the cutting width):
darita said:Does someone offer a gauge to set the guide stops? Rather than depending on my old eyes, it would be easier for me to set a gauge, then set both stops to that.
these work great for that,so do the newer rule stops, align to splinter guard and check both. Maybe woodpecker tool will make them againdarita said:Does someone offer a gauge to set the guide stops? Rather than depending on my old eyes, it would be easier for me to set a gauge, then set both stops to that.
