I'm building a clamp rack design that I found on lumberjocks and for the main structure I'm trying to just use dominos. So far so good but I've hit a snag trying to connect the sides to the base.
This is all 3/4" plywood the base is 24" square with a 3/4" rabbit on two sides that are about 3/8" deep. I was planning to use 6x40mm dominos but as I was setting up I noticed the bit would only be able to go about 3/4 of the way into the two pieces. Is there another long bit I can order from Festool or a 3rd party that will make a complete 40mm deep pocket?
