Just got my CMS + MFT/VL table combo with the TS75 module. I know that is NAINA but I think it may have more to do with the TS75 itself and hopefully some of you may help me.
First of all I love this combo, especially with the sliding table... Its smooth and a couple of steps up from my previous Dewalt 745 with an Incra miter gauge. I've got some really crisp cuts with this setup, that are perfectly square (checked with my Woodpecker square).
Using the knob and lever to adjust the height of the saw blade seems to work ok but what worries me is that I find myself needing to put pressure on the TS75 when locking it into the 0 degree and 45 degree bevel settings. If I don't do this the saw will settle at slightly off 0 degrees and slightly less than 45 degrees. I did some testing and by pushing quite hard on the saw, holding it in place while tightening the bevel screws I can get close but it just doesn't seem right.
Can I adjust this somehow so that I get a positive and reliant stop for the 0 and 45 degree bevels?
I'm also fine with having to use my Woodpecker square and Incra Angle to increase the precision but I wouldn't want to have to put any pressure on the machine.
Thanks!
Thanks!
