EWTHeckman
- Aug 18, 2011
Since my RO 125 is new and I'm getting ready to do a lot of work with it, I've been practicing with some scrap pieces of wood. But I've been struggling with the RO trying to take off in all different directions on me. It'll be good through part of a stroke, and I'll be moving it as smoothly and evenly as possible, then it'll suddenly go off on some random tear, sometimes even trying to change direction several times a second. I eventually get the piece nice, but this is exhausting.
I have it hooked up to a CT 26, and this happens even with the suction turned all the way down. The piece of scrap I'm sanding is clamped down to an admittedly shaky surface, (a Stanley Workmate Pro) but I've pushed it up against a much more stable workbench with no change. It's 3/4" thick Poplar. This occurs in both rotary and random orbit modes. The paper I'm using is all Granat, grits ranging from 60 to 220. It also happened with both the hard pad and the stock (medium) pad. I've tried varying the pressure I'm using with no change. I've also tried varying the the speed between 3 and 6, again, it continues to happen.
I'm probably doing something wrong, but I can't figure it out. Suggestions?
