How do you dry fit domino joinery?
zapdafish
Used the domino on my first real project today. I was making the base for a workbench and usng the 10 x 50 tenons.
The dominos were very tight fitting and as I was putting everything together but I was able to use my hands to insert them. I knew it was gonna be a son of a b***h to take apart. Damn thing took me a few mins to fit together and prob 1/2 an hour banging on things with a rubber mallet and vice grips to separate the components and get out all the dominos. Is there a better way? Should I buy some spreader clamps? Not looking forward to dry fitting the top support of the workbench now.
FYI, I used to use pocket holes for just about everything so dry fitting was cake.
Several things that you can do.  Microwave your dominoes - drives the moisture out and shrinks them a little.  Create one set for test fitting - sand them to get a looser fit.  Mark and keep those separately.  If you can, use a wider setting.
+1 what Peter said just make a few loose fitting dominos mark them with a felt tip pen and keep them for future projects
JMB
Thanks for that.  I'm just about ready to dry fit a couple of bedside tables, and wasn't smart enough to come up with that myself.
Take a box knife (utility knife) and peel off the sides  (edges only!) of the domino.  Dry fitting is much easier for the narrow mortised dominos.  I also a very lightly sanded set of dominos for test fitting,  It is very easy to get dry fitted joints apart
Dry fitting is for wimps. Get out the glue and go for it.
[tongue]
An oldie but goldie. I have a dozen of each size slightly sanded with a few holes drilled to pry out with a screwdriver.
Yep, both ends Ken. Im not sure who was the original poster here on FOG with this idea (a long time ago) but its a ripper.
I must have missed that tip the first time around.  And the holes make them obvious they're for dry fitting only.  Good tip, so thanks to our mystery FOG poster. [thumbs up]
jmbfestool said:
Yeah good idea!  I'll be stealing the hole idea!
Jmb
You're too late I stole it while you were still in bed this morning [big grin]
jmbfestool said:
Festoolfootstool said:
Jmb
DAM YOU!
Well ill do square holes then!  Patented pending!
Don't bother trying to market it in Germany, nobody there will have a compatible screwdriver.
I like it. Thanks
fdengel said:
Jmb
DAM YOU!
[thumbs up] [not worthy]
