alltracman78 said:
Well the base gives you just over 5.5mm, so you should be fine.
I was under the impression the 1.5* base was better for edge band trimming though?
I don't do edge banding, so I can't speak from experience.
This is one crazy timed thread. 5 years to the first comment, and then over 7 years to the next resurrection? Ok.....
Any way, alltrackman78 the 1.5 degree base is more geared toward thin edgebanding. Once you get into thicker edges, you will notice the angle. Your parts start to look like they have a beveled edge, rather than nice and flush.
The limiting factor of either base is the cut-length of bit that will fit in it.
[member=50264]levib1[/member] how much you can trim off at once is a little dependent on the wood species itself. Some types of wood will take that, others will splinter and rip out chunks.
I would rip your edges narrower in the future, assuming that it will not cause you problems getting it applied correctly. I would strive for taking less than 2mm.
I think I would adjust the cutter up to only take about 1/2 of that material in the first pass. Cut all of your parts like that, then adjust closer, for a second pass.
If you rip narrower later, you can skip the 2 pass method.
Sapele is pretty hard, so it might be splintery, though I have never edged with it?
If (and that's a big IF) you are comfortable with it, climb cutting is a very good way to combat splintering. Since you are talking about only 3mm edges, it should be fine. There isn't much material to grab, but still be very cautious with this. And absolutely don't try it with that full 4mm depth.
