Based in part on the suggestion of several FOG members, I recently bought a Bosch 4100 table saw. My primary purpose was to do repetitive rip cuts, such as for face frames. I need the portability of a benchtop saw, because I'm having to share the garage with two cars, and I love the Gravity-Rise stand and the riving knife/blade guard.
In the course of setting up the saw, however, I measured the blade to ensure that it was parallel to the miter gauge slots. To my surprise, it turned out to be about 0.025" out of alignment. I followed the manual's directions for adjusting the blade's alignment, but the alignment brackets seemed designed to prevent adjustment, because the holes for their bolts aren't slotted. The result is that retightening the bolts simply returns the blade more or less to its original misalignment. I called Bosch and was told that a misalignment of 0.010" was within their specs, because the saw is considered a contractor's saw. They also confirmed that, unlike the 4000 saw, the 4100 is not designed to allow such adjustments. I hate the idea of disassembling and packing up the saw, but this bothers me.
Should this be a big enough concern to return the saw, or should I just adjust the fence and miter gauge to be parallel/square to the blade? If you advise returning the saw, should I take my chances with another one or look elsewhere? Thanks for any feedback.
