[member=75310]surfjungle[/member] You’re most welcome. Here’s a link to the 250mm blades;
https://topstools.com/product/5pcs-t1044d-250mm-6-tpi-extra-long-jigsaw-blades-jstt1044d/
These are generic versions of the Bosch T1044’s and are only 6tpi so they’ll do the job. It’s not worth buying premium blades because they wear out just as quickly as the generic ones in my experience, and only three quid a blade is significant - because you’ll get through some. Bear in mind that 250mm is the overall blade length - the actual cutting capacity is 200mm. Set the saw’s pendulum action to maximum, go slowly, and let the machine do its job. Once the blade starts to dull and the saw starts to struggle - change the blade.
Re the half-laps - I use 18mm kiln-dried oak dowel. You’ll find it at most timber merchants. Use an 18mm spade bit to drill through the top part of the lap, and once you’re through to the bottom part - swap to a 17mm bit for the other half of the joint. Use a utility knife to ‘shave’ the ‘entry’ part of the dowel into a gentle wedge shape (you only need to remove a few mm, just enough to allow it to enter your hidden 17mm hole). Shave just the last 50mm or so. Then insert the peg into the 18mm hole, and hammer it home with a mallet. You’ll obviously feel resistance once the dowel enters the 17mm section - but a tight fit is the the whole idea. Finally - cut the peg flush at the exposed face (a good excuse to buy a Japanese Ryoba saw). One peg will do the job - but I usually use either 2 or 3 depending on the width of the sleeper. Your spade bits;
Screwfix part no. 130RR (17mm x 400mm long)
Screwfix part no. 790RR (18mm version of above)
And finally - moving sleepers around is best done using a sack truck. Screwfix part no. 3602P is a cheap-but-strong one with a 300kg capacity. Also great for paving slabs, bags of gravel, washing machines, fridges etc. If you need to move heavy stuff over a non-hard surface - go backwards, pulling the truck towards you rather than pushing it.
Hope the above helps. Best of luck with the project.
Kevin
