I got a Sys3 237 toolbox with the intention of making a plywood insert to store tools vertically for easy access, and it would be ideal if I could remove the lid ring, otherwise I can't make a full size insert and fit it through the opening. I emailed Festool support to see if it was possible and they said it would damage the pins. I'm wondering if anyone else has tried it.
The back pins are easily removable, I don't have any other SYS3 or T-LOC systainers to compare to, but they look the same as what I've seen online. There are two pins that look like they're pushed from the inside out, that capture the front of the lid ring to hold it in place. Those two I've tried prying on them gently with car trim removal tools and they don't budge at all.
