I suspect the hose will either be PE ( rather difficult to glue ) or PP ( quite easily glued ). I suggest you try a hotmelt glue. Alsmost all tape will eventually fail and the glue attracts dust, etc. Self amalgamating tape ( zelf vulcaniserende tape ) is the exception and might do very well, but you have to wrap it quite tightly to do the trick, I don't know if the hose will be able to take that. If it ddoes, that may well be the most permanent solution.
Regards,
Job
			Regards,
Job
