Don't forget that the distance of the guides isn't the only distance involved. I went out and measured my setup and with the guide set at 110 hanging off the non-cut side of the rail, it was 447 from the inside of the pin to the centerline of the router plate.
By my math, your panel is about 609.6mm minus offset, not sure what it is because you have it listed from the back panel rabbit, but lets say a total of 180, is 429. That would be inside the 447 max and so the video method should work for you.
--edit--
Gonna leave the above because that's what I originally put, but I forgot to mention I hung my guid off the outer t-track, which is where I got the extra 20-some mm from.
That being said, even if you didn't want to use the outer t-track, you could use the inner t-track and push the pin block out past the 110mm line and still get it secure on the guide, that should get you to > 435mm.
-Lee
