What bit would you use on a Festool router to cut a perfect 38" Dia circle on 3" oak stock? I was thinking of using a Tremel?, and routhing down about halfway, then turning it over and going down the balance of the 3" .
What type of bit would you use? Straight bit or UpCut bit? Also, when using a trammel, will you be left with a hole in the center where the pivot point is.
