Kodi Crescent
- Aug 6, 2010
Hi. I'm building a work bench table. Essentially a top with supports in the side and in the middle. Each of the supports runs the width of the table, and will be dominoed and glued into place.
While fitting the top, I got a bit overzealous with the power planer on the middle support. This leaves me a gap of about 2mm between the center support and the bottom of the table. This support will be dominoed to the table. The domino mortises have already been cut. I'd like to get as much glue surface between the table and the supports to minimize any racking, so I'm looking for some way to fix my goof. This is built out of Poplar.
I'm thinking of a few options and would like some opinions.
1. I could glue a new piece of poplar on the middle support and then plane it back down to the appropriate level, recut the dominos for the support and glue the top on.
2. I could plane a bit off the underside of the table on each end, and adjust the domino height before I glue it into place. The table is laminated poplar pieces, laminated on end, with a thickness of about 2". I'm a novice with the power plane, so I'm afraid I may do more damage. Plus I'm a novice with a hand plane, and I tend to get really bad tearout on this.
3. I could do nothing and leave the gap.
4. I could fill the gap with some sort of putty (e.g. Minwax high performance filler) at the time I glue the dominos in place.
I'm open to other options. Any advice on how to fix this?
Thanks!
Thanks!
