so... pretty simple project - a hutch.. 47 inches wide, 3 shelves with one vertical divider in between. Now hold you opinion on the thickness of the stock, it's gonna be 1/2" maple ply.
So my question is surrounding the joinery of the shelves to the vertical divider. I built an identical hutch before i got the df 500, and i was using pocket holes. The joining process was not necessarily easy, but it was very strong. Major drawbacks was that i Got frustrated with filling the pocket holes later.
Pretty sure the domino will solve that, using 5x30 tenons. Now my question is that, is it advisable to mortise through the vertical divider and then the two horizontal shelves would just tenon into that common mortise space with the 5x30.
Two pros:
1) guarantee the two horizontal shelves would be aligned perfectly
2) don't have to mortise both sides of the vertical divider.
but will that kind of joinery not very strong, as comparing to making one mortise for one tenon? Bear in mind that this is a hutch and will not be bearing much weight. Just some decorative stuff.
the whole ply carcass will be face framed with poplar.
Thank you all!
Two pros:
Thank you all!
