I've been going back and forth for a while trying to decide if I wanted to invest in an HVLP system and I've decided I do want one but I'm not sure how much of one to buy.
With the kids about grown and the major house remodeling about finished up I've had time to play woodworker lately instead of carpenter/drywall guy/plumber/electrician etc.
I've recently built garage cabinets and cabinets for the finished basement and have several more to build along with closet builtins and bookcases. Brushing on a finish takes more time than I want to spend, I'm not a guy that loves finishing, and I'd like to learn to lay down a quality finish in the future. I don't really expect to achieve what the professionals achieve but I think I can learn to do quality work. I've always been a Polycrylic kind of guy and recently used General Finishes water based poly and Enduro Var, both much nicer than Polycrylic.
My immediate problem is I have no idea how much sprayer to buy or what finish to buy. My current thinking is that I'll only spray waterborne clear finishes or shellac but who knows what the future will bring. Although I don't see ever spraying latex I might want to use pigmented lacquer in the future. I'm sure I'll have a million questions as I learn and I'll try not to ask them all but I'm hoping you can help me get my feet wet.
I like quality tools hence my growing collection of systainers but I try to avoid buying more than I think I need.
I was thinking Fuji 3 stage but can go 4 or even 5 stage if my applications above warrant it.
Gravity or cup?
What clear finish to buy? Reading back through the forum I saw SW Wood Classics recommended so I plan n grabbing a gallon of the waterborne poly varnish in the morning. Their website states brush on or spray so I figure I can use a brush now and as soon as I get a sprayer it's something I can use to at least start learning with. They have 30% off right now so it's also economical to work with.
If I understand correctly I'll generally be able to recoat after an hour or so. Is the finish ok in the gun and tip between coats? I wouldn't think you have to strip things down and clean between coats.
Can I really spray in my garage or basement shop without making a mess if I rig up a temp spray booth with plastic sheeting? The dust collection of Festoys is one of the biggest reasons I've been able to rekindle my woodworking. Festool lets me cut, sand, and rout without making an unholy mess.
Lastly for now, is there a HVLP for dummies you can recommend that might be of some help with the basics?
Gravity or cup?
