makpacman
- Mar 21, 2023
Steve1 said:I still have no idea where I am going wrong. But I don't give up easy.
Any suggestions ?
Looking back at my previous results, the only places I got beautifully smooth finish is where I overlapped the spray on the rails and stiles --- so simply not thick enough ?
Your tenacity leads me to believe you'll find great results AND be able to recreate them.
If you're getting a desireable finish in the overlapped areas and there are no drips or runs anywhere else you probably just need to lay down more material. There are several ways to go about this. Get closer, increase overlap, increase fluid flow to air ratio. If youre worried about runs, sags, practice on some folded construction paper(according like) to see how easily runs start.
I don't stop spraying the if the sheen isn't fully glossy and uniform in my reflected light source. The square edges become a bit round and bulbous, and by all means it "looks" like it may end up with runs or drips. But if I was fairly methodical with the application and thoughtful in respraying dryer areas, and the viscosity is close(doesn't even have to be perfect) usually there won't be drips. Any I do find, I'll fix by immediately pulling paint off with a dry brush. With today's paints, if the material holds for the first few minutes, you're likely good to go and drips won't magically materialize overnight like they used to.
Though not great, it's def not end of the world to get a small drip or run. If you get 99% of the project perfect a touch up or two usually goes unnoticed, especially after a week passes.
Attached is an example of how heavy you can coat without defects if spraying on horizontal surfaces. Once dry, all doors were perfect, zero touchups needed. And even with this heavy a coat, it still took 3 coats to get that really luxurious finish you're probably after.
Keep at it. You're close.
