HowardH
- Jan 23, 2007
A couple of years ago I made the commitment to save some space and go all Festool so I sold my table saw. Most of the time it has worked out but when it comes to cutting for example drawer sides, fronts and backs, I am having trouble figuring out how to make exact repetitive pieces, especially ripping to width. With the table saw, you only have set up the fence and start ripping away, every piece will be the exact same width. Even crosscutting using a crosscut sled with a stop for the length is much easier. I have an older MFT 1080 and removed the fence since I couldn't depend on it being a perfect 90 for crosscuts [huh] [huh] so now I use the Qwas Dogs which gives me a square cut but no way to accurately repeat the same rip width. There simply isn't enough room to the right of the guiderail to make a stop work. If the board is less than 2 feet long, I use the dogs and my MFS 400 as a fence of sorts but it only works on short pieces not to mention the time it takes to set up. What else do you do to make repetitive rip cuts? Right now, I'm making a printer stand for my new office and I know I could have cut down at least 4-5 hours spent if I had a good table saw. My top and bottom are maple and required a glue up to make the panels the right size. I ended up jointing one edge and then standing them on edge and running them through my planer to make them parallel for a square glue up. [blink] There has to be an easier way.
